I dl this movies in 2 and it was in 2 parts... both .avi play fine....... i also can convert the second one with no problems to a mpeg2 for dvd.... but everytime thru at 59 percent (or somewhere in the 50's) when i try to convert the first file it gives me a "INVALID FLOATING POINT OPERATION" error and makes me start over again...... can anyone help me wit this one.... thanks
hey mol3000, judging by your number of posts you are not a newcomer to these forums, therefore you must realise there is a search button at the top, musn't you??
first of all y was this post moved????? second of all do virt dub work now?????? i always have trbl with that piece of garbage software.....!!!!!!! is there anyother software i can use???????? and if not how do i search for junk frames using dub
Before you post
Please try to do some basic research before posting. Most fundamental questions are answered on the How To's on this site or at other locations on the web.
Using the Forum search feature can yield rich rewards as most questions have already been previously answered.
These questions are answered several times and that's why it is not an advanced topic. People who are willing to answer such a question again and again will probably look at the newbie conversion forum.
So moving your topic to this forum should help to get more replies. -
Post moved was itOriginally Posted by mol3000
I did not notice, will you see the moderators around here have nothing to do, so give them a break. Vdub is the best
if your having problems with it, this is your system
However you may like to try Vdub-MP3
Here is some info from the "King Johns shortcuts"
Virtual Dub MP3 Freeze
Removing junk frames with Vdub MP3 freeze requires some work, this version will make a log of any junk frames at C:\junkframes.log using this log, you can easily remove the junk frames.
File > Open video file
Video > Check video for freezes
When the scan has finished, leave Vdub on screen and open the log file using Windows notepad
Bad Frame Report from VirtualDub-Mp3
12345
12346
12347
12348
12349
345678
345679
345680
345681
From the example shown, we can see there are 2 groups of numbers. Each group having a sequence of bad frames. You need to start at the highest groups first, if you did not do this, the other numbers would no longer be in the same location. You also need to mark start and end at key frames.
Highlight the first number in the highest group (345678) and select "Copy" (Control C) now switch back to Vdub and select Edit > Go to and paste that number into the box (Control V)
You will see Vdub give an error, you now need to jump backwards to the nearest key frame.
Click the yellow key frame Icon once Then mark this as start by clicking the start Icon. Go back to the log and highlight the last number in the group (345681) and select "Copy" (Control C) now switch back to Vdub and select Edit > Go to and paste that number into the box (Control V)
You will see Vdub give an error, you now need to jump Forward to the nearest key frame.
Then mark this as end by clicking the end Icon.
Press your delete key to remove this group of bad frames.
You now need to do the same for the next grope of numbers. When you have finished deleting all bad frames, save the AVI
Video > Direct steam copy
Audio > Direct stream copy
SAVE AVI (Movie2.AVI)
Looks better in HTML
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 10:28 -
How do you take red (or other color) out of every frame
By deezin in forum Newbie / General discussionsReplies: 10Last Post: 24th Jan 2009, 11:57 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 15:58 -
[color=red]Huge annoying title[/color]
By JohnnyMalaria in forum TestReplies: 1Last Post: 1st Feb 2008, 11:47 -
[color=red]hd again[/color]
By gunukhan in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Jul 2007, 14:17
